show isis topology
show isis topology {area area_name {level [1 | 2]}} {ipv4 | ipv6}
Description
This command displays the topology for IPv4, IPv6, or both IPv4 and IPv6 for the specified area and level.
Syntax Description
area_name Specifies the router process for which the topology applies.
level [1 | 2] Specifies the IS-IS level of the topology you want to view.
ipv4 Selects the IPv4 topology for display. If you omit the ipv4 and ipv6 options, the IPv4 topology appears.
ipv6 Selects the IPv6 topology for display. If you omit this option, the IPv4 topology appears.
Default
None.
Usage Guidelines
Each known IS in the area or domain is displayed along with the next-hop and metric information.
The following command display IPv4 topology information for areax:
show isis topology area areax ipv4
Platform Availability
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
